Anyone know how to contact Chris Salas (qik33)?
I'm a little confused. The choke line is the far left side of the map, and you're on the right of centre. Did you mean something else? Maybe the dotted line running up the middle of the island? That's just following the peak efficiency line. It's nothing to be worried about.
It's on a Mustang dyno. They're the lowest reading dynos on the market. He's actually pulling it out to replace it with a mainline next week. I wouldn't be surprised to see another 40-60whp on a mainline. I'm starting to believe that it's possible I'm closer to the 700whp mark and from my compressor map I did the calculations on above, this would put me close to the choke line. If this is the case, unless I can rev the engine higher which I currently can't, I may just need a larger turbo. So either go Precision 6670 Next gen, NEO head or solid lifter conversation. I'm going to go back on the dyno next Friday and try a final hail Mary pass though before I explore those options. I'll play with my exhaust cam timing and feed it 32+ PSI. I have not dragged the car with the new setup. Two young kids at home. I'll get back into it sooner then later. -
Yes agreed, but more then likely on an RB26 that has another 1000rpm of rev limit. Nothing silly with the exhaust, I fabbed everything. 6boost manifold.
