Calling GTR owners
"Budget" and modifying a GTR dont exactly go hand in hand. Dont even think about turbos if u are only going to put in 5k!
First: Full exhaust system (trubo's back)
Second: Pod Filters with appropriate ducting
Third & Fourth: Intercooler upgrade and or Cam Gears
By doing this, boost will rise a little as it is not being restricted as much.
Its at this stage that your injectors are nearing max and fuel pump is getting strained.
From there on its "Speed costs Money, how fast do you want to go?"
Boost controller, injectors, fuelpump, new computer management, oil/air separator, turbos, clutch ect....ect...
https://www.sau.com.au/forums/topic/4800-calling-gtr-owners/#findComment-75564
Sorry dude my car already has some mods done..
Power FC
Airfilter
Front pipes
Hi flow cat
Cat back
1 bar boost
Platinum Plugs
Phased Cams
But now i want more and some people are telling me dont bother with changing too much as it will open a can of works with more and more money to spend.
So just Hi flow the Std GTR Turbos and max out everything.
Or
Buy new turbos say GT2530's and max everything out.
Help me Dude.
Cheers
https://www.sau.com.au/forums/topic/4800-calling-gtr-owners/#findComment-75592
Fit a larger, more efficient cooler. Your power FC (hand controller) will tell you what duty your injectors are at. As for turbos well you cant go past the 2530's or 2535's with their associated dump pipes (the ones where the internal wastegate has a separate pipe). Both bolt onto the standard manifold and are safe for around 2 bar.
Remember that if you do go the new turbo option, you WILL need larger injectors 550cc+, larger fuel pump (you can buy bosch in-tank fuel pumps to suit GTR's) and just to be on the safe side, oil/air separator, and oil cooler. Also a twin plate clutch is also a good idea, as well as new suspension (for handling the extra power and more control/feel). Upgrade brake pads to something like EBC green/blue/yellow stuff for increased stopping.
This should net you around 300rwkw. Providing that it is tuned properly (on a dyno is a good way) there is no reason that you need to open the motor. The Gearbox is still safe providing you treat it nicely. Anymore power than this and it starts to get into big HP and big dollar fields.
https://www.sau.com.au/forums/topic/4800-calling-gtr-owners/#findComment-75624
had one previously so may be able to comment.... I'd do cam gears first before anything then twin plate clutch - guy on here Emre has done an 11.9 I think with std turbos, just clutch and cam gears, pods, dump pipes and exhaust running 17psi or so.. Std cooler is good for 500hp or so, lot better than people think.. Also get your car on the dyno and tuned properly also.. As well injectors will start to max out soon.. go at least 550cc or larger if you are planning on bigger turbos.. GTR is a weapon waiting to be unleashed.
https://www.sau.com.au/forums/topic/4800-calling-gtr-owners/#findComment-75781
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
