Hey guys,
I'm having a hard time figuring out just what disassembly is required to replace the front parking lights in the V36 Coupe.
I've had a go by taking the airbox out, but it seems that the parking light bulb is slightly below the fog light, and covered with layers of wiring, making it hard to get to.
Anyone got suggestions? Hoping I don't have to take my bumper off to get to them.
The lamps are in a socket which unlocks with a 1/4 turn clockwise (as seen from the front of the vehicle looking back).
You definitely need to take out the air boxes to get the clearance you need but as you've already noticed, the wire harness isn't all that generous. If you're not careful, you could do damage to your wiring. Though I do get away with that method, I would recommend you treat it as a headlight replacement - jack the car up, remove the inner wheel well cover and access it from there.
  • Thanks 1
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
