just wondering if anyone else has a knocking sound on there car while it idles. i'm looking at buying a car that does...apparently had it for past 10,000km drives really well. i've read past posts and people say it goes away when u press the clutch but i havent tried this as i dind't think of that when i checked it out. it's like a rhythmic knocking sound. it got checked by RACV comprehensive check and they said they couldn't tell me wat it was without removing the whole thing and they weren't aloud to do that coz i don't own the car. any help on wat it could be and how expensive it wud be to fix would be great. thanks
https://www.sau.com.au/forums/topic/48467-knocking-sound-on-idle/
I had a smillar noise on idle which came from the timing case. Took it some where and was told it was probably the belt. It did in fact work out to be the belt (timing belt) which was loose causing it to knock on the cover. They replaced the belt and tensioner and cost $500. Nearly asked for an ambulance mind you. F---in rip off.
wat gets me is that the RACV comprehensive mechanic check couldn't tell me wat it was...without taking removing belt/s to locate. they said it was coming from the drive belt area...is that the same as u???
probably but the report says something bout having to "remove belt/s to locate"...u think he means that it could be that...probably some stupid old man mechanic who doesn't know wat a skyline is...i'm jsut really worried i'm gonna buy this thing with ll my money and end up having to shell out another $1,000 to fix it. how much should i pay for a timingblet change in Melb. the clock says 85,000kms so maybe/most likely wound back and is due for timingblet change as it hasn't been done and the cars been here for 2 years...so
I was worried about buying my car too at the time so i took my mate who is a mechanic. He could only see the basics ie wierd noises, panel damage etc. Good idea to try and get somebody who actually knows about skylines because my friend didn't see a couple of things. EG the aircon belt was missing ended up costing 1000 for complete new system. And the timing belt soon after. Car had 60000km on it when i bought it but somehow dont believe it. As i said you did the right thing by getting an RACV check but if you know someone who knows about skylines get them to check it out.
As for timing belt cost. The belt $100 The tensioner $90-100. And about 3 to 4 hours labour max. So anywhere from 50-70 roughly per hour. I would have gone somewhere else but the work shop just took it upon themselves to do the work then tell me it was ready. Oh yeah was told the timing belt is the same as a VL. But double check.
thanks so much for ur help... is there any way i can check if it's gonna be the timing belt. like a test or something. i think everything else on the car is alright...cept for a few minor problems...water gettin into the boot...panels got repaired except they didn't replace the rubber properly. basically just little things afta that. i'll see how it goes.
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
