r33 Skyline1995 Posted July 3, 2023 Share Posted July 3, 2023 Hello all, In need of a fuel sender for my 1995 Skyline R33 GTS25T coupe. Picture of item needed attached. I'm in NJ zip code 07801 in the USA so will need shipped which I will pay. If any available please let me know. Thanks Vic Link to comment https://www.sau.com.au/forums/topic/484779-need-a-skyline-r33-gts25t-coupe-fuel-sender/ Share on other sites More sharing options...
StubbyFoil Posted July 5, 2023 Share Posted July 5, 2023 (edited) I just went through this same issue in the USA. The part is discontinued, and there was only a couple really beat up senders for sale on ebay. These are very tempermental, and break/corrode very easily. I found a company in Seattle, WA that makes aftermarket senders and I had them make me one to my specs. Its a 0-90ohm sender, which is the same as OEM Nissan. Its 18 inches long, and is E85 compatible (which costs extra). The company is called ISSPRO. The custom part number should just be "R33". I dont see it on their website, but if you call them, and ask for Don, he should know exactly what youre talking about. I think they charged me $175 plus shipping, but honestly I didnt care because most of the used, beat up OEM senders were that much or more. Hope this helps! EDIT: Their custom made sender slips into the factory "clamshell" of the OEM sender. I popped open the OEM sender by pressing on the tabs, opened the clamshell and gutted all of the OEM electronics. Then I trimmed about 1" off of the top off of the OEM clamshell, and slipped the aftermarket sender in. Drilled a couple holes in the clamshell for zipties and ziptied the sender at top and bottom so it doesnt bang around inside the fuel tank or clamshell. It uses the OEM bracket inside the tank and hangs there just like normal. Edited July 5, 2023 by StubbyFoil 1 Link to comment https://www.sau.com.au/forums/topic/484779-need-a-skyline-r33-gts25t-coupe-fuel-sender/#findComment-7981056 Share on other sites More sharing options...
