Just wondering has anyone done any dyno runs with toluene?? Just did two runs on the weekend, one with out and one with Toluene. 160 with out and 166 with the Toluene in. The mixture was only 7:1 and still got a result, just a fluke or has anyone else also had any good results?? :confused:
https://www.sau.com.au/forums/topic/4890-toluene/
Originally posted by U ZCREAM
Hmmm, you should be careful with that stuff. I hear it can dry out your injectors. But if you're only using a small amount for a short period, you should be fine
You are thinking of methanol (I think?). Toluene doesn't have this effect. The problem with toluene is getting a cold start when you run too high a mixture on a cold day.
MattR - It's good stuff isn't it.
:D
I've had a test on mine, no dyno time just a nice 200kms worth of driving. You will find that you can run more boost as well (within the limits of your headgasket and turbo of course). I ran a brief 14psi to test and it went fine.
With extra boost I'm sure you can get more than 166. BTW what mixture did you run?
From memory mine was 25-30%, I'd say a 10-15% would be better without a remapp unless you go extra boost.
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-76174
Gav as far as I know Toluene an Metholbenzene are diffarant according to the material safety data sheets. Toluene can be bought as a solvent or as a fuel addative, if you buy it as a solvent you pay about $50 for 20 litres if you buy it for a addative you pay about $70.
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-76952
Actually correct chemical name IS methylbenzene, (methobenzene is also commonly used but is a misnomer).
I stole 4 litres when I did my chemistry/metallurgy degree (too many years ago now) and mixed it in the fule tank of my EK Holden (202 tripple f*ck yous, a lumpy seat and exagerators).
Thems were the day me boy!
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-77134
MattR.. You run a bleed setup don't you?
You should be getting boost drop to 12 maybe 13psi up top.
Slap more boost in to it.. Maybe up to 17psi in the mid but it will drop back off to 13psi up top anyhow..
I ran my turbo like that for a while didn't damage it as far as I know.. Now with the EBC it holds 15psi all the way to redline and made 164rwkw with a untuned ecu.. So with a tuned ecu i might crack the 170 mark.. :D
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-77251
http://forums.skylinesaustralia.com/showth...25&pagenumber=1
This is an previous thread on toluene, covers most of the questions, including the myth about toluene perishing fuel hoses.
BTW I think Boostmeister had a dyno run with 30%toluene mix and got 2rwkw extra without raising the boost any (where the extra power lives)
MattR; The stock turbo shouldn't have the boost raised past 1 bar anyway, so its of little value unless you get it rebuilt with a steel wheel.
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-77831
Oh you still running stock cooler..
Maybe thats why the octane boost made such a difference as the air is hot and maybe there was really slight detonation where the ecu was pulling out timing and with the octane boost there was no more detonation..?!?
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-78163
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
    • thanks, will conduct myself accordingly. i unfortunately put about 150 miles on the car before reading this thread again, however no PS issues, and definitely no turbo issues. it spools normally and still feels fast to me, probably because my previous car was an N/A auto sedan...gonna go fix the PS vacuum line though lol. safe to say, got what i came to this thread for. thanks
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
