hey guys i have heard some guy tell me he was able to maintain drift on 3rd gear in his s13 sylvia. How is this possible when he has pretty much the same amount of power i do. ~150rwkw. As i personally can only manage to hold drift in 2nd in the ceffy. Maybe its just my technique?
BTW if there is a thread somwhere on this pleas epoint me. Ill like to know.
https://www.sau.com.au/forums/topic/48978-drifting-techniques-in-the-ceffy/
remember that its not power that counts in drifting...
ur cars much heavier than an S13 and weight has a big part in it... plus what handling mods does he have?
suspension setup is integral also and plays a massive part.
yeah i know power hasnt much to do.. but ive seen him drift and he enters drift on the same part of the road that i do. Just im assuming he has picked up more speed.
yeah u have apoint in his suspension setup. Apparenlty hes got a very tight lsd setup on his with bushes and 3000 bux of coilovers (HA and dampener adjustable). Mines is a very loose compared to his(mech diff). thats what ive been thinking is the main diff.
How does weight play in this? Ive only been drifting seriuosly for like 4 months or so. So im still getting the theorise sorted out.
uve been drifting for longer than i have... i have only mucked around a little in my old 32... but nothing properly on a track.
but i do read a lot... weight is going to play a HUGE factor when comparing ur HP/KW... hes only 150kw but his car is about 100kgs lighter... this means he will be able to accelerate faster than u... his car will also have a lower center of gravity... better weight distribution... all playing a major factor in how well the car is able to go into a corner.
Yeah, I have read a few times 200kgs is about 30hp, not sure if its right or not but hey.
Id say diff, and suspension would help. Mines a bit easy to get the arse out at times. Like Im almost never trying to get it taily, and it just starts to kick out, fun but yeah, can draw attention.
ive drifted my old mr2 gt b4 and it was nutting compared to the ceffy.. It so tail happy. :Bang:
Still im gonna see if can hold drift in 3rd next time. As my rev limiter cuts out at 7200 on 2nd and holding at 80km/h. So hoping to get better drift on 3rd at say 100km/h on 3rd. I think abit more practice toi get used to the car is in order.
BTW thnax guys. I did forget the power weight equation. Yesh those s13s are much lighter.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
