To keep with the trend of distinguishing which members are where, Here is a list of the WA Cefiro Owners:
- Jai "jaik" - Black, RB20DET
- Steve "MrMayhem" - White, SR20DET
- Mark "summoner" - Blue, RB26DETT - Was in WA but now in QLD
- Bam "G0DF4Th3R" - Blue, RB20DET
- Stewart "StilledCefiro" - Wine Red, RB25DET
- James "Jimmah" - Black, RB20DET
- Rowan "Mr Eps" - White, RB20DE
- Adam - Pearl White, RB25DET
- Nic - Yellow, RB25DET
Obviously, if you're not on the list let us know in the thread.
Currently I am contemplating starting a Cefiro Owners Club, Similar to SilviaWA, so that we can have a nice big fleet of taxis parading around the city all nice and together like :P Who else in WA would be keen for a meet up and a cruise to a pub?
JK
https://www.sau.com.au/forums/topic/49203-wa-cefiro-owners/
  • Replies 44
I think when we get our shit together we should be able to pull 10-15 for a cruise
i dont think there be enough for a ceffwa yet
theres about 7 ceffy owners in antilag.com
go and pimp them to here! :P
https://www.sau.com.au/forums/topic/49203-wa-cefiro-owners/#findComment-984839
  • 4 weeks later...
Get Jiggy everyone,
I am the McMahon chap with the RB20DE, :Oops: (hurrah)
it's ok, soon she shall sit on 18's, hehe and be converted to el'turbio 'e'grande, one day....and manual, one day....
ANYWAY all i really had to say is there's another guy in perth (pete(?))with a two tone silver / gunmetal RB20DET conv. with similar wheels to gOdF4TheR's ride,
and there's one puttering around freo, which looks kinda like mine (white) but covered in dents and full of rust...(a common problem with the A31's shell.)
there's another getting around my area which is white too.... i've spotted it twice but never seen again... which seems to be identical to my car... maybe i dreamt it?
So there's some more you can add to the list, also i think there was a champagney reddy coloured one brought into WA? off prestige???
he may be on the list, hes pretty heavy modded... and nice,
and the black Hoist racing one... but he's probably already there,
https://www.sau.com.au/forums/topic/49203-wa-cefiro-owners/#findComment-1018033
Ps: as a side note, Mr Mayhem did you convert your one to SR yourself or was that done by previous owner? if so, was it hard? i've been considering SR for fuel consumption / weight distrobution / newer engine...
is it much different to drive from an RB powered one?
https://www.sau.com.au/forums/topic/49203-wa-cefiro-owners/#findComment-1018037
  • 2 years later...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
