IS HERE!
Just got the call from Gareth that the car has been dropped off :)
Front bar is in the car... im guessing it was too low to move around withit on.
Im just waiting for my camera to charge and my cousin to get outta bed and WHERE OFF! :(
https://www.sau.com.au/forums/topic/49465-the-beast/
  • Replies 73
it was dropped off at his place by truck...
im going to pick it up and store it here until i can comply it... while its here i'll do all the fluids and easy stuff.
hopefully the rds dry up by the time i get there and it doesnt rain more.
https://www.sau.com.au/forums/topic/49465-the-beast/#findComment-987400
as long as you don't have lead foot-itis then u got nothing to worry about...
my ceffy had tiny tiny wheels so it was dori dori all the way from the docks... you've got GTR style rims so turakushon shouldn't be a problem.
https://www.sau.com.au/forums/topic/49465-the-beast/#findComment-987407
havent taken many pics cause it needs a cleaning :P
took this tho... its only being reved to 4000 but u kinda get the idea... http://home.iprimus.com.au/fairy_princess/MVI_0003.AVI
i drove it home from gareths in glen waverly and oh boy was that fun... scared the begeesus out of people on the side of road and the people with the windows down :(
heres a few pics... check out the size of the bloody oil cooler ;)
http://www.superhonda.com/photopost/showga...00&ppuser=69108
the funniest thing about it is the paint on the engine bay :rant: its glitterised
https://www.sau.com.au/forums/topic/49465-the-beast/#findComment-988100
the LSD is pretty mental... not used to driving a car with such a mental LSD.
even turning corners at 15kmh u can hear it trying to spin the wheels... its weird.
my cousin was pissing himself laughing at the looks from people when i started to boot it :P
https://www.sau.com.au/forums/topic/49465-the-beast/#findComment-988125
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
