Time to sell it as i have too many cars and not enough room... or money, to keep them all. Very quick and modable car.
Pics located here:
http://www.skylinesaustralia.com/photopost.../500/ppuser/414
Specs:
Model: JZZ30 Soarer
Engine: 1JZGTE 2.5Litre Twin Turbo
Trans: Auto
Colour: Green Metalic
KMS: 74000
Reged til FEB 2005
Standard Features
-Air Con
-Power Steering
-TEMS
-Digital Dash
-Electrically adjustable seats
-Traction Control
And all the other usual mod cons.
Mods:
-Vertex Style front bar and skirts
-17x8.5 Front and 17x9.5 rear ZEITT Alloys
-235 rubber all round
-3.5 inch catback exhaust (thats the pipe from the cat not the tip)
-HKS super filter (green mushroom type)
-Boost guage (7 colours)
-Sony CDX-M850MP CD Player (flip down face and graphic EQ)
-Audioline 1200w 4channel amp (red one with the blue LED)
-Clarion TV (retractable in dash)
-Pager alarm
-Turbo Timer
Had a major service about 4 months ago...
Replaced all belts (timing belt included) and most of the heater/radiator hoses... also had the radiator core and top tank replaced as they were 80% clogged when we got it.
Serviced with Mobil oils on a regular basis and only used high octane fuel. generally optimax as thats the clostest to my house.
Asking: $16500ono WILL SELL FOR LESS WITHOUT THE AV EQUIPMENT.
Contact: Nik 0422 930 505 or email me at [email protected]
https://www.sau.com.au/forums/topic/49562-fs-toyota-soarer-tt-melb/
  • 1 month later...
ok puting this back up for sale...
front bar was damaged recently due to spastic and a tow bar and will be repaired and now it seems the bloody front suspension is squeeking so that is now scheduled to be fixed.
also replacing the brake pads on the rear as theyre almost out.
AC screen seems to be playing up but still works fine.
once that is all sorted out and the rwc is done it will be ready to go.
had to put the stock exhaust back on for the RWC and will leave it on until the car is sold.
last person who came to test drive it when it was for sale was impressed... but dreaming about the price.
NEW price will be $14000 FIRM with out the TV, Stereo and AMP... 15500 if u want the AV gear.
Will put up some pics and vids within the week.
  • 6 months later...
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
