Help! Car missing - Need New Exhuast Valve (Have Questions - labor prices/required)
Recently got my stock standard r33 from the compliancing workshop. Went in fine and came out missing pretty bad - car was missing @ stand still position at low revs, also stuggles to accelerate. Was told my mechanic that i'm goin to need new exhuast valves.
Compression test showed one cylinder was @ 115 and the other 5 were @ 170
Have put new sparkplugs, old ones looked fine when taken out.
Coil packs are working fine.
AFM is working fine.
The mechanic has pinned point that i require new exhuast valves. I only have very very basic mechanical knowledge, what is required to change the exhuast valves ... i was quoted $1500 for the whole job. What is involved ... and does the price sound right to get it the job done? Is this pretty tricky or through the right guidance a possible home job?
regards
bryanlee
Get a second opinion. Based on your compression readings you have 5 good cylinders and one bad. You certainly shouldn't need to replace ALL the exhaust valves. Your mechanic should be able to identify the problem with the bad cylinder - the best way is a leakdown test.
If you have limited mechanical knowledge, best let someone do it for you.
Also I'd be asking some q's about why the car went into the shop running fine but came out running crap....usually doesn't 'just happen' like that....
yeah the workshop doesnt know either ... they r a decent bunch of blokes there. Nothing sus on the workshop. More on the vehicle. Mechanic of the workshop reckon its an electrical fault. But besides the coils, plugs, leads, afm or the ecu ... i cant see what the issue could be. Does $1500 sound right to get the exhuast valves changed? Its a fairly big job from what i heard ... understand the problem just occured overnight. Not through a span of time. What other problems could it be?
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
