Alo...guys...i'm a new members here...Gonna find a skyline R33 GTS-T....around $17500k.....prefer with sport rims, bodykit, or gauges, FMIC, exhaust....location prefer tasmania or victoria...phone num : 0422176909
https://www.sau.com.au/forums/topic/50267-wtb-r33/
  • 3 weeks later...
