GFB Stealth FX
Guest darrinspencer
It is not on the Gold Coast but delivery is overnight
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi..._PcY_BIN_Stores
I have bought of them before with no worries
I have sent them a email to see if they will do a group buy price for 3 or more
I will let you know if it is cheaer than $440 plus delivery
I have seen the wholesale price on these and they are not much more then
$300-320 so there is a fair bit of makeup.
https://www.sau.com.au/forums/topic/50432-gfb-stealth-fx/#findComment-1004021
the whole top peice which holds on the boost control line fell off
somewhere on the road. i had no idea it had come loose or was coming loose.
i had to fabricate up a peice for the top with some rubber seals to make it work again and a nut to hold it onto the main shaft. i only had it for 6-7 months and it fell apart. :mad::mad:
i have attached pics so you can see what i am talking about. i like the valve but i am not sure about the build quality. it is fantastic with the adjustability.
just a warning before you spend serious bucks... :(
https://www.sau.com.au/forums/topic/50432-gfb-stealth-fx/#findComment-1007176
Guest neoGT-25
i had to fabricate up a peice for the top with some rubber seals to make it work again and a nut to hold it onto the main shaft. i only had it for 6-7 months and it fell apart. :D  :)
just a warning before you spend serious bucks... :D
dosent it have a warrenty or something?
https://www.sau.com.au/forums/topic/50432-gfb-stealth-fx/#findComment-1007606
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
