Did someone say they wanted Buddy Clubs rims...
http://www.slidewizeimports.com/products/i...index.turn.html
As Burto will tell you, the QFs in 18X10 will take a long time to get here but they are very nice rims! We can also get TE37s but they are around $1100 a rim from memory (but are in stock and ready to send tomorrow if required).
How much delivered would a set of 18x8 and 18x9 White TE37's be delivered to melbourne and how long will take to arrive once payment is made for a r33 gts-t
Hi All
We sell TE37s in 18" for $4400 a set. Courier Australia wide is $100, or pickup is available in Melbourne.
Used rims we can source from Japan, however it will be several months before we have a container coming to Melbourne. If you want to wait that long though, we can have used 18'S with rubber for around $2000, 17's even less. Just depends on brand, type of vehicle they will fit, condition etc.
For any further info just send an email : )
when was the last time you were able to bring in a decent set of second hand TE37's for around 2g?
__________________
INASNT, I havent brought in used TE37s previously, as we sell them new.
Slidewize Imports normally only does smaller items that can be sent via air. Bulky/heavy items like rims, exhausts, etc we can have sent via shipping container. It will be several months before we are sending a container to melbourne however. I plan to send items via shipping container on a regular basis in the future, but at this point it is not worthwhile to do them often.
I have a set of 18" x 9.5 NISMO LM-GT1's to suit an R33 GTR.
I also have a set of white 19" x 9.5 TE-37's
Don't ask for photo's as I'm up in Weipa at the moment...I fly back on Thursday the 16th. till Tuesday....if the people in Brisbane are willing to come and make an offer, when they have a look?
[email protected]
The most recent examples of standard R34 GTR rims I have seen in Japan have sold for between $1800-$2100 including all fees Japan side. The only other costs are getting the rims to Australia (freight, import duty, GST) also then freight from Melbourne to where ever you are located. Some 18X10 BBS LM rims sold for $1700 recently. Also seen some 17X8 BBS LMs (only two rims though for R33 GTSt, so not much use to most people) sell for only $250!
Out of interest, standard R33 GTR rims and tyres have been selling for around $1400.
All up around $3000 would be realistic for a set of R34 GTR rims, maybe a tad less (this is with tyres). Prices dont vary a great deal without tyres.
We wont have a shipping container leaving for several months for heavy/larger items, so if you are in a hurry probably best to look elsewhere at this point. Any smaller items are being sent via EMS (electronics, turbos and even coilovers sometimes).
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
