Hi Guys,
My RNN14 GTI-R is now up for sale. Here is all the details I can think of!
12/92 Nissan Pulsar GTI-R, black. 79000 k’s.
Interior:
Momo “Race” steering wheel
Razo gear knob and pedals
HKS type one multi timer/meter
Trust/Greddy 60mm boost gauge
Genuine Nissan floor mats
Factory power sunroof (very rare option)
Power windows
Retractable power mirrors
Air conditioning
Engine:
Chipped ecu
Exhaust – 3 inch front pipe, 3 inch high flow cat, 3 inch custom cat back system
Braided turbo oil feed line
Braided clutch line
Trust frount mount intercooler
Trust Type S blow off valve
Turbosmart bleed valve (set to 0.8 bar)
Urethane Engine mounts
M’s pod filter
Veilside oil filler cap
Cusco radiator cap
Twin core alloy Calsonic radiator
NGK high tension plug leads with NGK platinum spark plugs
Suspension and brakes:
Factory ABS brakes
Front strut brace
Rear strut brace
Race brakes front and rear brake pads, with slotted rotors
ADR compliant braided brake lines all around
Rebuilt rear callipers
Clutch pedal bracket
Tein type HA damper and height adjustable coil-over suspension
Whiteline Anti-lift kit
Whiteline adjustable rear sway bar
Whiteline link bushes and sway bar D bushes
Whiteline camber kit
Exterior:
Clear side and front indicators with silver fusion indicator bulbs
Alloy wheels with Toyo Trampio Tyres
New front bumper bar with tow hook cover
Stereo and alarm system:
Sony Head unit with 3, 4 volt pre outs
Clarion two channel amp, powering;
Boston Acoustics 6.5inch splits
Alpine 2 channel amp, powering;
Rockford Fosgate 10 inch sub
Flashpoint Level 4 alarm with 3 point immobiliser
History:
This car was imported in late 2002, by JappSport (formerly Fuji Motorsport) in Sydney. I was the first Australian owner, buying the car in December 2002. Since owning the car I have spent in excess of $10 000 to make the car what it is today, a neat, quick reliable street car :rant:. The stereo and alarm set-up alone was over $3000 and all suspension components were bought brand new with around $3000 spent there too.
Always serviced with Castrol formula R, 10W60 and genuine Nissan oil filters. Brake fluid used is Trust Super DOT 4.
All suspension components were professionally installed and set-up at Whiteline Suspension in Sydney.
All of the stereo and alarm components were installed by Lifestyle Car Audio.
The exhaust was custom made by Liverpool Exhausts
All other mechanical/service work was carried out at Rice Engineering in Sydney
The car has been dyno tuned to 156 all wheel kilowatts at only 0.85 bar boost at Premier Auto Centre.
Timing chain tensioner has been replaced and the timing chain inspected. CV boots have been replaced. Clutch master cylinder has been rebuilt. Starter motor has been replaced. Front wheel bearings have been replaced. All accessory belts have been replaced. Fuel filter has been changed. Engine has excellent compression across all cylinders.
The car has just under 4 months registration remaining.
This car has been owned and cared for by a true nissan enthusiast. The only reason I'm even selling it now is because I now own a GTR skyline. Registering, insuring and maintaining two cars is a bit silly for someone who doesn't even drive to work!
Asking $19 000.
I can't re-size the pics at work and one is 115kb the other is 142, if someone could do if for me so that I can upload them that would be great. Or whoever wants pics can request them here and I'll email them. Car is located in Sydney.
Please contact me (Richard) on 0405 186 433
Cheers. :cheers:
https://www.sau.com.au/forums/topic/50616-rnn14-gti-r/
Thanks mate.
Had plenty of calls and interest, but no-one has walked away with the keys yet.
Also, no swaps for other cars, I've already bought another car which is why I'm selling this one!
Richard
https://www.sau.com.au/forums/topic/50616-rnn14-gti-r/#findComment-1046852
link to pics says its been sold??
That's weird! Maybe they do that when you don't re-sucbscribe the ad? hmmm.
I'll give carpoint a ring.
Anyway, it's still for sale :D
Richard
https://www.sau.com.au/forums/topic/50616-rnn14-gti-r/#findComment-1062078
  • 4 weeks later...
bumped, still for sale. I'm now getting more keen to sell as the GTR is getting closer to arriving in Sydney. Anyone who's interested don't let the price put you off, it's a great car and I'll be happy to negotiate with an interested buyer.
Richard
https://www.sau.com.au/forums/topic/50616-rnn14-gti-r/#findComment-1087249
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
