nismo single plate clutch,to suit 33gtr, pull type, built by jim berry, (RACE CLUTCH) in brisbane, fully modifiyed with 4650lbs pressure plate, carbonite plates from the states, this is one off two clutches built for a gtr by him. this clutch is easy to drive not like a triple plate and can hold up the 800hp at the wheels which proved it in my personal gtr, this clutch has done 1800kms, and reason off selling is going to a push type to suit the new dog box i have ordered otherwise i would keep it. come with flywheel, all balanced to suit the clucth. asking $900 the lot. cost me $1600new.
dont have pics till early next week cause its coming out off the car then. but if anyones intrested email me for further info.
[email protected]
https://www.sau.com.au/forums/topic/50642-nismo-single-plate/
  • 3 weeks later...
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
