Hi Guys,
What would be a safe Air / Fuel Ratio for an RB25DET running 14PSI - Everyday?? I have been told that a safe cruise level is around 14.7 / 1. My current cruise setting is 11.5 / 1. Can this in time cause oil to wash from the bore and what other dangers would I be looking at?? Thanks in advance.....
https://www.sau.com.au/forums/topic/50900-safe-afrs/
I agree around 11.5 to 12.1 is the safest... anything above 12.5 on boost could mean trouble for the engine. on cruising not sure, but as long as no boost, i guess 14 is ok. 11 on cruise is way too rich, something is wrong man
https://www.sau.com.au/forums/topic/50900-safe-afrs/#findComment-1009677
Have you got white smoke comming out your exhaust ?
If so, your ring lands are probaly on thier way out !
If he said car is using a bit of oil, so I reckon the exhaust smoke should have a bluish colour if it's burning oil. ring land issue too.. or perhaps oil seal on turbo, either way, better get it checked.
https://www.sau.com.au/forums/topic/50900-safe-afrs/#findComment-1012219
I run 15:1 at light throttle on my GTR no problem at all. 40 to 42 degrees timing No problem. Once over 3600rpm though I increase it to 14:1, still 40 degrees timing too.
Boost> as per above posts :D
I think your car has a problem ....
Mike
https://www.sau.com.au/forums/topic/50900-safe-afrs/#findComment-1014057
    • What's on the front of their building?
    • Jax Tyres Smithfeild Ive gone there a few time, well for tyres. on my 3rd visit I spoke to the dude and told how i just got slugged for rotors, brakes ect. His reply was golden; have you read whats on the front of the building. Never forgot it.       before picture, good friend got all these goodies installed.  Well time to study, servicing, maintenance all before this weekend driving lesson.
    • Hello, first of, I’ve looked at many threads on this code but none have helped me, if you know one that will help me feel free to post a link.   Now to my problem. Recently I was driving and noticed the check engine light came on. I went home and did the test to see what code it gave. I got the 21 code but everything seems fine with the car, no misfire, idle is good, acceleration is the same as when I bought it. I mean no signs of obvious failure. If no misfire is happening I can rule out the coil packs right? Which is about 98% of posts saying it is. If anyone has had this happen and found the issues let me know please. No other lights are on.   The car WAS due for an oil change. I since then changed it so idk if that triggers code 21. Either way it hasn’t turned off.
    • Your both right, it may hold a bit longer then.  Soon I need to change the synchros, should I fit the billet plate while I'm at it? Or just a waste of money?
    • Some of the east coast US Stagea got together this past weekend at Lime Rock Park in CT for Grid Life Circuit Legends. This is probably my favorite pic of the shoot with @Morgan.Mundahl on IG. Hope we get more stags out next year! i think I spotted 5 other than my own at the event.
