I'm having trouble getting a bonnet, RHF quarter panel, and a RH headlight for my series 1 R33. Also I could really do with a cut out of the radiator support bar thanks to the idiot that pulled in front of me :D
I have emailed "jap parts wa" twice and they don’t even respond, I spose I’ll try ringing on Monday.
Only response I have got out of the 5 or so jap places is justjap, and they where expensive as hell (1000 for a bumper pfft) and c-red couldn’t help me.
Is there anywhere else (preferably in WA) i can try and source these parts from?
I miss driving my line...
Alex.
https://www.sau.com.au/forums/topic/50946-sourcing-r33-body-panels-in-wa/
Alex.
Call RAJ on 0894932191 and he will have the bits you need, was their the other day and I think computer was down,
I've got some of the stuff you need. I bought a frt cut to fix a car I previously owned. I know I have standard frt bar, 1/2 Radiator support and R Fender. Give me a call 0419 907 796 and I'll check what else is still there.
Cheers for that.
Yeah $650 for standard and $1000 for 'm spec' plus I would of had to get it from over east somehow. dreeeamin.
PM ME DETAILS ABOUT SOTCK FNT BAR!!!
I NEED ONE BADLY AND I WILL TAKE IT IF PRICE IS RIGHT!!!!
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
