CV (cheval-vapeur) is french horspower dude :D
PS = Pferdestärke (Horse Strength German) which is Metric Horsepower(probably where you got the French bit from). Sometimes referred to as Power Stroke.
1 PS = 0.735kW
1 hp = 0.746kW
https://www.sau.com.au/forums/topic/50984-kw-hp-ps/#findComment-1010745
Yeah ps is almost exactly equal to bhp. A page of conversions can be found here:
http://www.citroen.co.uk/conversion/c_conv...converter_rates
Stall/torque converters are the fluid couplings that autos use in place of a clutch. Basically, its an internally finned, fluid filled housing attached to the engine with a fan-like impeller attached to the gearbox shaft inside it. As the finned housing turns the movement of the fluid turns the gearbox fan & inturn moves the car.
Changing the design/size/angle of the blades in the converter changes it's 'hook up' (rpm range where the car begins to move significantly) properties. The idea of a 4500 stally is to delay the hook up till later in the rpm range (circa 4500rpm, but not necessarily right on it) where the engine is making plenty of power. Great for allowing big laggy turbs to spool up but not so practical for heading down to the shops due to you engine having to do 4000-5000rpm constantly to keep the car moving.
Ballpark figure for a std stally would be around 1200-1800 car dependant...
https://www.sau.com.au/forums/topic/50984-kw-hp-ps/#findComment-1010751
Cheers, exactly what i wanted to know...
That Conversion page is good but im still guessing on one thing. My dyno read i had 1100 Lb of Torque, I'm guessing this would be Lb-ft? Converted to Nm its like 811. Thats sounds too high for my 218 rwkw car.
Lb-f to Newtons was 247. I read that big v8s have like 400 - 500 Nm, it just sounds a bit crazy that my 2.5 L on 12psi has more Torque *with 811* than those big fat v8s. Have i converted this right? If not how how do i know my Nm. Thanks,
https://www.sau.com.au/forums/topic/50984-kw-hp-ps/#findComment-1010925
you have to multiply it by the distance away from the load object... whatever that is... might be the radius of your wheels, but that sounds too low. I've never understood how torque applies to cars... I think its how many apples it can move a metre or something lol...
I'm digressing... basically, the 800Nm is too high, there is a distance in there, hopefully someone else can tell u what that is.
https://www.sau.com.au/forums/topic/50984-kw-hp-ps/#findComment-1011299
Torque on a dyno means shit, unless it's an engine dyno
The gear your in, diff ratios, rims size amount of rubber, tailshaft length all kinds of stuff
Killowatts/HP/PS is the mesure of energy being produced basically how much chemical potential energy (the air/fuel mix) is being turned into kinetic energy, which in turn gets used to spin the crank etc etc.
Torque is a mesaure of the amount of "twisting" force being applied. Cars have gearboxes and diffs to change the torque output becuase otherwise you would go nowhere fast
It's confusing, they sound like the same thing but there not, and i cant think of a better way to explain it (i'm like that i know what i'm trying to say i just cant do it very well ;) )
https://www.sau.com.au/forums/topic/50984-kw-hp-ps/#findComment-1011654
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
    • My mechanic installed all the parts and then got it tuned which i think is around the corner from him
