I like the grill look like the GTR.
As on the meggala's rb25 ceffy and the ceffy posted above.
Ceffo - the one you posted would look good without the chrome bit i think, just the stealth black grill thats sunken in a bit i think that'd look nice too.
https://www.sau.com.au/forums/topic/51235-cef-on-prestige/#findComment-1016177
The chrome grill is from the later model A31, They seem to sought after in Japan, similar to the late model tail lights, they all want them also.
I am half way there.......got the grill, but still early tailights.
Daveo.........thats what your car could look like with a mild kit and some DISH :)
https://www.sau.com.au/forums/topic/51235-cef-on-prestige/#findComment-1016355
Yes thats rather bizzare the posting bit... OBVIOUSLY my post had to be there before yours hahaha
I dont understand what you mean about filing it away for an oil cooler... my mate has the same style grille as you, so theres atleast 3 types that we know of. You can tell because your Cefiro logo is positioned higher on the grille whereas mine is somewhat located down a bit on that divider down the middle.
Im considering doing some el cheapo ducting off the drivers side grille vent to my oil cooler as its right behind it.
JK
https://www.sau.com.au/forums/topic/51235-cef-on-prestige/#findComment-1016442
oh ok... i thought they just might have cut the bit out of it for better air flow... altho u cant even see the oil cooler behind there its about the same length as the grille if not a little bigger and higher :)
so many options on these bloody things...
https://www.sau.com.au/forums/topic/51235-cef-on-prestige/#findComment-1016448
