hes in hpi 8 with that mental ae86 they made for a customer and take on the track for circuit racing...
aparently an email i wrote a couple of months ago was published in the latest hpi saying that it was one of his.... which would explain the WONDER sticker on the bucket as thats who he was sponsored by...
i cant find any footage of him tho and his website is down www.kenworks.net
i cant find any more on him.
https://www.sau.com.au/forums/topic/51361-cef-zlas-own0r/#findComment-1017584
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
