i figured coz the stagea is new i might as well be the first to get a custom made exhaust. it was done by my local performance exhaust shop, southport exhaust, and starts with stock manifold, a custom dump pipe (r33 doesn't fit coz of something) then mild steel 3in, hi flow cat and zetti muffler. All up, $1,000 bucks. immediately you notice the increase in torque and top end power and sounds awesome as well. :headspin:
https://www.sau.com.au/forums/topic/51626-exhaust/#findComment-1021209
Oooops, It thought they were the same. The Blitz catalogue lists the same engine pipe part number for R33 GTST and WGN34 Stagea.
Blitz Front Pipe ECR33 Stegia WGNC34
¥15,360.00
Care to check with your exhaust guy and find out what exactly was different. It would be a great help :D
https://www.sau.com.au/forums/topic/51626-exhaust/#findComment-1021245
Hahaha, funny how I come home and the first thread I read is this one seems I JUST picked the Stagea up from the exhaust shop !!
Just got done a turbo back 3 inch system. Custom one piece dump/front pipe, high flow cat, resonator then into a 3 inch muffler. All up it was $900 (but I supplied the cat).
They did a very nice job of it. Very tidy welds, all sits nice and snug under the car (no problems with clearance), all the mandrel bends are perfect etc.. Very happy with it.
I haven't had a chance to give it a good test yet - too much traffic around, but I'll take her out later tonight.
I've got the whole exhaust system here at home, as well as a stock R33 GTS-t dump and front pipe, so I'll be able to assemble the two and do a direct comparison of them...
I did notice that on the Nissan Fast part program, the part numbers for the Stagea front and dump pipe are the same as the R33 GTS-t dump and front pipe !!
And I just remembered that I was going to take some pics of the exhaust while it was up on the hoist.... And damn it, I forgot.... Sorry...
J
https://www.sau.com.au/forums/topic/51626-exhaust/#findComment-1021309
I have bought a s/s cat back Apexi N1 exhaust system for my Stagea when it arrives. Will that be enough on the exhaust side of things? I read somewhere (think it was a Zoom mag) that the cats on these cars aren't that restrictive. Is this true? Should I buy a high flow cat? What else do I need?
https://www.sau.com.au/forums/topic/51626-exhaust/#findComment-1021761
hey guys i was wondering is there enough room under the stagea to run twin 3" to the rear either together or one each side, crossing over under the tailshaft or something????
i would like a complete twin 3" system (one from each turbo all the way to twin exhuast at the rear bumper)
could i fit 2 mufflers on each pipe??? and 1 cat on each??? :confused:
prolly wont fit but just asking before i purchase a stagea :jump:
i want it to be very queit and not be excessivly loud like the engine is in the vl atm with a hotdog muffler and another rear resonator, deafening is the word :uhh:
cya guys
Brad
https://www.sau.com.au/forums/topic/51626-exhaust/#findComment-1034422
I drove an R32 GTR that had a twin 2.5 inch exhaust from the turbo back, including twin cats. It had a twin inlet/outlet resonator under the passengers floor and a twin inlet/outlet muffler at the rear. It was quiet, but had a purposeful note.
https://www.sau.com.au/forums/topic/51626-exhaust/#findComment-1034495
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
