i figured coz the stagea is new i might as well be the first to get a custom made exhaust. it was done by my local performance exhaust shop, southport exhaust, and starts with stock manifold, a custom dump pipe (r33 doesn't fit coz of something) then mild steel 3in, hi flow cat and zetti muffler. All up, $1,000 bucks. immediately you notice the increase in torque and top end power and sounds awesome as well. :headspin:
https://www.sau.com.au/forums/topic/51626-exhaust/#findComment-1021209
Oooops, It thought they were the same. The Blitz catalogue lists the same engine pipe part number for R33 GTST and WGN34 Stagea.
Blitz Front Pipe ECR33 Stegia WGNC34
¥15,360.00
Care to check with your exhaust guy and find out what exactly was different. It would be a great help :D
https://www.sau.com.au/forums/topic/51626-exhaust/#findComment-1021245
Hahaha, funny how I come home and the first thread I read is this one seems I JUST picked the Stagea up from the exhaust shop !!
Just got done a turbo back 3 inch system. Custom one piece dump/front pipe, high flow cat, resonator then into a 3 inch muffler. All up it was $900 (but I supplied the cat).
They did a very nice job of it. Very tidy welds, all sits nice and snug under the car (no problems with clearance), all the mandrel bends are perfect etc.. Very happy with it.
I haven't had a chance to give it a good test yet - too much traffic around, but I'll take her out later tonight.
I've got the whole exhaust system here at home, as well as a stock R33 GTS-t dump and front pipe, so I'll be able to assemble the two and do a direct comparison of them...
I did notice that on the Nissan Fast part program, the part numbers for the Stagea front and dump pipe are the same as the R33 GTS-t dump and front pipe !!
And I just remembered that I was going to take some pics of the exhaust while it was up on the hoist.... And damn it, I forgot.... Sorry...
J
https://www.sau.com.au/forums/topic/51626-exhaust/#findComment-1021309
I have bought a s/s cat back Apexi N1 exhaust system for my Stagea when it arrives. Will that be enough on the exhaust side of things? I read somewhere (think it was a Zoom mag) that the cats on these cars aren't that restrictive. Is this true? Should I buy a high flow cat? What else do I need?
https://www.sau.com.au/forums/topic/51626-exhaust/#findComment-1021761
hey guys i was wondering is there enough room under the stagea to run twin 3" to the rear either together or one each side, crossing over under the tailshaft or something????
i would like a complete twin 3" system (one from each turbo all the way to twin exhuast at the rear bumper)
could i fit 2 mufflers on each pipe??? and 1 cat on each??? :confused:
prolly wont fit but just asking before i purchase a stagea :jump:
i want it to be very queit and not be excessivly loud like the engine is in the vl atm with a hotdog muffler and another rear resonator, deafening is the word :uhh:
cya guys
Brad
https://www.sau.com.au/forums/topic/51626-exhaust/#findComment-1034422
I drove an R32 GTR that had a twin 2.5 inch exhaust from the turbo back, including twin cats. It had a twin inlet/outlet resonator under the passengers floor and a twin inlet/outlet muffler at the rear. It was quiet, but had a purposeful note.
https://www.sau.com.au/forums/topic/51626-exhaust/#findComment-1034495
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
