  • Replies 88
dinesh/andrew:- no worries guys, if yall need industry tickets for most events come to me first i will get them for you :D that goes for all you sau'ers
mel:- i love you long time, calling you LIVE right now ;)
hahaha see you all tommorow night,
time to get mashed uppppppppppppppppppp :grouphug:
adrian ;)
GoDSKITCHEN WAS THE SHIZNIT!!!!
man did they all perform or what? Halliwell was a good start, Fleming was who i was looking forward to, and he did not disappoint. Anne Savage, damn does that chick know some hard stuff!!! BK finished it off well also, but not as good as i thought. Overall, a fantastic night, and a lot of stayers. The upstairs area was filled with people all night.
Woke up at 4.30 and missed all my lectures...haha but it was worth it!
and i agree S13_angel, bring on MoS and SciFi! but i think mos is too close to exams for me haha.... but i have no excuse for ferry corsten + sci fi! :cheers:
hey guys!!!
flemming was wikid and infusion was cool too! missed anne savage :D
hehehe i was first to the cloak room and one of the last ppl out! i felt proud!!!
nice meeting you gradenko.
liz - thats FINE!!
adrian - was good to luv you long time! :cheers:
the four sets i went for, didn't dissapoint me :D
adam kelly,eddie haliwell, 00 fleming and infusion :) pure sicknessssss
word of advice to kenny l, don't try to be a superstar and play big tracks like traffic and adagio for strings when your only a warm up act to the international djs :)
it was ncie running into dan,liz,russ and mel good to see the sau'ers again :)
just got home from a full on bender of a weekend now off to be incharge of the midnight shift oh my god :D
adrian :cheers:
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
