Charcters on JDM plates?????????
Could someone please tell me what the character on the left of the numbers on Japanese rego plates mean?
I understand that the characters at the top of the plate denote the prefecture, I am simply curious what the single one means.
Thanks
ps. I put it here cause i figured you people living in Japan would know best......i apologise if this is not the appropriate place for this thread.
https://www.sau.com.au/forums/topic/52231-charcters-on-jdm-plates/
So it has no reference to vehicle type/mass etc?
Means nothing then?
that's the top numbers your refering to
- 500 (used to be 5x): depending on engine capacity, car weight and width which I don't know exactly but don't really care. As an example: most small sedans/hatches, coupes like integra, silvia, celica, roadster MR2/S, roadsters etc...early skylines, chasers, evos, sti, rx-7 I believe are in this class too.
- 300 (used to be 3x): same as above but larger, heavier class...NSX, Supra, GTO, GT-R, RX-7, Evo, Z32/33, RX-8, Chasers, Skylines, Stageas etc
- Yellow plates: kei plates... I don't take note of the numbers.
- 400: lorries, special vehicles
- 800 (used tobe 88): marked police cars and emergency services ambos, fire brigade
from what i heard here's how it goes, 2.1 liter engine and below is 500 plates, 2.2 and above is 300 plates, bus and trucks are 100. my wifes prelude is a 300 plate because its a 2.2 liter engine. thats the reason why r32 gts-t's and gts-4 has a 500 plate (and thats how u can tell if people just slapped in a gtr badge hehe).
the letter beside it doesnt really mean anything, except for us which is Y or E or A, which denotes (supposedly) tax free (but we still pay for it though, because the base commander "insist"). :bs!:
Yukio, as I said any of 3 main criterias I mentioned and also a few other things.
My Evo and a s14 are both 2.0L and have 300 plates...s13 and S15 are 500 plates...but it's no big deal. As you said only makes it easier to spot posers...but then I have seen RB26DETT in HNR32 with 500 plates.
Good that you mentioned it, I forgot about the 100 plates.
Also plates with a red diagonal line across the plates are dealer plates.
i think so too, but coz us here on US base we have different coding just to make it less complicated, they made it simple, yellow plates and motorcycles pay 3,000 yen, 500 plates pay 5,000 yen or some small number like that then 300 plates pay 19,990 yen then 300 plates with 4.5 liter engine and up pays 47,000 something yen for a year.
I thought the numbers, which denote tax code (right?) are also determined by the weight of the vehicle?
From what I have observed I think 300 plates are starting from 2.0L up capacity, 1200kg+ weight and 1700mm+ width.
Because the early Evos and WRX meets all of the above except for width and they are 500 plates...or the old 7x plates.
Justin I don't think the 1 has any significance, more they ran out of possible plates and just tag the additional digit to it....
I think the basic numbers, 1, 3, 5 etc are used and then each prefecture can add numbers after that dependening on needs...
so a 55 code is the same as a 500 code since they both start with a 5.
Over here in Yamanashi I've seen 55 / 500 / 501 / 33 / 300 / etc
One question - what the deal with a Kei car that has a black plate with yellow writing...not a yellow plate with black writing. Seen a couple about but could never figure it out.
Aaaah, I could be mistaken, but I remember someone saying the black plate with yellow writing is registered as a commercial vehicle...
as for the 5xx etc numbers - I asked that question at the dealership - was told that only the number of digits and the first digit are important - and that you could, in fact, choose the other digits if you liked
it was a 50:50 japanese/english conversation - it sounded a bit weird to me, so not sure if something was lost in translation
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
