Hey all im organising a summer bbq and cruise
15th dec, sunday
meet : glen waverely library
meet : 10am
depart 11am
its about a 1.5hr drive, its basically just to chill out and hav a few snags and drinks
maps will be handed out and also im co-ordinating this cruise with MCCR, nissansilvia.com, and u guys so im not sure what the turn out will be.
C u then !
https://www.sau.com.au/forums/topic/5260-bbq-cruise/
Look i have made the cruise invite only for MCCR, they r gonna be ppl wit good cars and not holdens/fords i respect cars and so do the ppl that r comin, i want Skyline Australia to be there just like Nissan Silvia and Skyline Downunder and im also tryin to get some members of Fang Artists, i understand the rep that MCCR has for muzzas but this is a day cruise for a bbq. A meet and greet basically so the muzzas wont be comin u know they r too busy puttin on their car bras for chapel and armoroilin their tyres ! C'mon i want this is to be dominated by Skylines and other turbo nissans !
Thanx Yoshi
https://www.sau.com.au/forums/topic/5260-bbq-cruise/#findComment-81486
I helped to organise a Nissan cruise a while ago, we had R31 skyline club, team NSE, ANTRX, the silvia club, the pulsar club, and the only people who acted like total wits were the ones with the big "MCCR" stickers......
who at a later date came into the R31 forums bitching that the cruise "wasn't fast enough"
Once something has been advertised on the MCCR forums, you can't control who's going to turn up.
It will be a free for all 'drag racing cruise' and I don't care what time of day it is.
It's not going to stop the dickhead factor.
:talk2hand
https://www.sau.com.au/forums/topic/5260-bbq-cruise/#findComment-81549
Well to be honest i feel the same way, hence i no longer go on the major Open and Supercruises too many heros'. And if u dont come i understand also, i just hope u dont respect me less becoz of mine affiliation wit MCCR. Look it was the first car club i joined and i learnt a lot from them, and a lot of the admin/moderators r nice ppl, just some of the newbies there r dicks i agree. Well i hope it is a good cruise if muzzas rock up im quitin MCCR thats for sure. So i'll keep u guys posted. Fingers crossed i mite see some of u there !
https://www.sau.com.au/forums/topic/5260-bbq-cruise/#findComment-81726
Well since i want more skylines to come eg the R32, R33 and R34 i will let u know the route
Basically goin from Glen Waverely -> Frankston -> Point Leo
If ppl want more fun we will do a Arthers Seat run too from Point Leo and there r plenty of 'private' roads if u feel the need !
https://www.sau.com.au/forums/topic/5260-bbq-cruise/#findComment-88115
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
