how many ks on your speedo at the moment? like my car has done 70k when i first got it. i confirmed this from the brake pads. The front was replaced with an aftermarket ones with about 50% left on the pads. And the rears are still the original brembo brake pads. So these are the little things that you can see. Tie rods see wheter they are still originals or not.
About 37000kms on mine. Still the original brakes as far as I know - has 'nissan' on them. Pads still have plenty left on them.
Pretty sure my rod bushes need replacing.
Based on the condition of the interior I reckon it is likely to have not been driven much.
Still, its therefore been sitting around for a long time and I dont really know which is worse - a car with higher km's or a car thats been sitting doing nothing for years.
I have major issues with my shock absorbers tho - rear right was leaking when I bought the car so had to have the rears replaced under warranty. Fronts still dampen but there's noticeable (but not too harsh) vibration from the front end (could be bushes), although steering still feels ok.
I guess the bottom line with any import (or any 2nd hand car really) is just to play it cautious for a year or so as you find out the actual condition of the car.
[/quote
yea and get them to get a mech to get it inspected its well worth it i think. cross your fingers i guess.]
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
