Hi everyone,
I have an auto tranny s2 r33. Has 3.5" cat back zorst, blitz pod filter, and boost is upped to 9psi via a turbosx boost controller. No other mods.
What benefits can i expect to get from a dyno run? What could be tuned to extract more power from this setup?
Thanks for your help =)
https://www.sau.com.au/forums/topic/53257-what-benefits-from-dyno/
Hi everyone,
Checking that all is well in the A/F ratio area would be my first priority. Then you could maximise the base ignition timing. That's about it.:rolleyes:
They are good for fault finding too. You might pick up an air/vacume leak while your on the dyno too.
It's a good way of checking the car under semi controlled conditions.
But if there's nothing wrong with your car, then there's not much point doing a dyno run.
J
Ok this may be a stupid question cos I don't know a lot about dyno tunning but i'll ask anyway...
When it's said you need an adjustable computer, does this include re-mapping the stock ecu? Would you need dyno tunning at the same time of the re-map?
Or do you just tell the person that is re-mapping what your mods are and that is enough?
You can buy a premapped chip, but every engine is different. So the more accurate way is to real time tune the chip on the dyno.:P
Thanks for the helpful advice =)
i think i'll wait out on the dyno run until i get some more mods :(
Tigger if you've upped your boost then dont. I also have auto tranny but more importantly i upped my boost - put it on the dyno and found out i need a new fuel pump - unfortunately the damage was already done and eventually engine went BAM.
Moral of story is its good to check air/fuel ratios etc ..... incase your fuel pump is on the way out.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
