  • Replies 381
i think youse should grow up... if you really hate each other do something about it and stop sweet gay top bloke talking to each other.
who says we hate each other?
we should grow up? mmmmmmmmmmm right
maybe u should not read things that might offend ur delicate eyes... this is a forum... on this forum we like to have a bit of fun... perhaps its starting to make u doubt ur own sexuality? Just stop reading.
Relax tiger, these trashy post are a common occurance, it's just thier way of working out there sexuall and bedroom frustrations and issues. They like to air them in public then retire for a long evening of make up sex. Personally it's not my kit but I make a decent cut from pimping VL-ULEH's ass. Ni really isn't cutting it at the moment!
That reminds me, where's my money BITCH! :Pimp2:
Hey at least they havn't whored someone elses thead huh.
exactly, this is my thread... everytime ive told u to shut ya mouth its cause ur blabbin on in someone elses thread where its not cared for...
and... ummm... denham u usual warrior of the plastic word board.... am i a mod? :)
aaa INASNT.. u my friend. i still need to keep a promise to..
u coming down next friday to calder?
I see enough vl driving wankers on the road at any given time, so y would i bother coming all the way to calder to watch you either go into the wall or hand nark his ass on a platter
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
