  • Replies 381
i think youse should grow up... if you really hate each other do something about it and stop sweet gay top bloke talking to each other.
who says we hate each other?
we should grow up? mmmmmmmmmmm right
maybe u should not read things that might offend ur delicate eyes... this is a forum... on this forum we like to have a bit of fun... perhaps its starting to make u doubt ur own sexuality? Just stop reading.
Relax tiger, these trashy post are a common occurance, it's just thier way of working out there sexuall and bedroom frustrations and issues. They like to air them in public then retire for a long evening of make up sex. Personally it's not my kit but I make a decent cut from pimping VL-ULEH's ass. Ni really isn't cutting it at the moment!
That reminds me, where's my money BITCH! :Pimp2:
Hey at least they havn't whored someone elses thead huh.
exactly, this is my thread... everytime ive told u to shut ya mouth its cause ur blabbin on in someone elses thread where its not cared for...
and... ummm... denham u usual warrior of the plastic word board.... am i a mod? :)
aaa INASNT.. u my friend. i still need to keep a promise to..
u coming down next friday to calder?
I see enough vl driving wankers on the road at any given time, so y would i bother coming all the way to calder to watch you either go into the wall or hand nark his ass on a platter
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
