had to go for a drive after lunch ... i might have pissed of a guy cause i turned onto a main road .. but there was 2 lanes and the bastard was clearly speeding anyways... so anyways i turn onto the main road and the guy passes me on the main road so its not like i didn't give way and so we come to a stop light ... he starts yelling towards me as if he was speaking asian ... i could clearly see that his passenger didnt' really like what he was doing ... but guess what car he was driving?? ... thats right it was a typical vn commie ... had bogan written all over it ... anyways swear to god if it wasn't in broad day light i'd get out the car and smash his car ...
https://www.sau.com.au/forums/topic/53955-racism/
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
