Does anyone know the guy who drives this car its a black r32 with the plates either GTS 308 or GTS 303 the guy is also on p plates.
Last night he nearly ran me off the road while overtaking me at about 900km in a 60 zone. He drives like a complete tosser...this was in the carnegie area......
:cuss:
https://www.sau.com.au/forums/topic/5402-gts-308-or-gts-303/
Not a bad looking car when stopped
yeah its a nice looking car but as we can read in other threads....
"guys in other skylines who look at you and think they are sick c..unts.. and also think they are better" they suck thats what this guy is
he is a tosser....also he has a fast car it has def been moded (as i saw it outside gts on dandy road) however when I pulled up next to him he didnt give me a friendly wave or a smile he just stared straight through me.... i dislike him argh
:headshot:
https://www.sau.com.au/forums/topic/5402-gts-308-or-gts-303/#findComment-83383
Righto. Will keep a lookout.
My Civic looks like a normal red Civic hatch (except it usually has bike carriers on the roof) :) Skyline has been ordered - but not here yet. Thinking 'AKIRA' for the plate?
The other car is more recognizable - Red Lada Niva convertible with 'EX-KGB' plate :)
I live in Sth Yarra - and have seen GTS-308 alot on Chapel St.
James W
https://www.sau.com.au/forums/topic/5402-gts-308-or-gts-303/#findComment-83390
need I say more
as i always say when down chapel(walking and drinking at pubs) look at these tossers trying to show off their cars why dont they just go on a sick drive and puch their car drive it how it is meant to be driven....eg: out to the dandeongs of out to geelong.. they use the same petrol and have twice as much fun,,,, wankers on chapel ......... PPFFFTTTTTTTTT:shake:
https://www.sau.com.au/forums/topic/5402-gts-308-or-gts-303/#findComment-83393
Ak:
> what does this mean what have you ordered tell me the specs
Series 3 '98 R33 GT-R Vspec
Midnight Purple Pearl
Stock to the max :)
Will add PowerFC and breathing system (filter/exhaust only) here.
I'm being very picky about the car and having a problem fiding one in the right colour. Lots of silver and white - but no purple :)
Getting it through GTA in the city - guy left a message for me today at the office - so maybe a good sign.
I don't spend $60k every day - so I'm not compromising what I want :)
Will keep you posted.
James W
https://www.sau.com.au/forums/topic/5402-gts-308-or-gts-303/#findComment-83397
drool drool
thats exactly what I want I knew...stressing "knew" a guy selling one of these for 55k it was sooooo nice I want a purple r33 gtr thats my next car...when you get it we;ll cruise uo to the dandeongs so i can show ur car up :) ...!1 pEaCE
https://www.sau.com.au/forums/topic/5402-gts-308-or-gts-303/#findComment-83398
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
