When I was driving Water Taxi's we were forever dropping near naked bucks at the many islands around the harbour. I once had to fish a bucks out of the water trying to swim from Clark island to rushcutters bay.....
Had one guy who "appeared" on fort dennison wearing convict clothing and a legiron with bowling ball. The chain was short enough so he could not carry the ball while walking, so he had to bend over and stumble along.
The best was a charter boat with 30 guys and 2 strippers......there were lost of drugs and lots of sex.....
Another fun one is drunk/stoned go-carting...butterfly farm is good for these type of things
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
