Standard / Aftermarket BOV (Plumb Back) ASAP.
they are the same type of bov, but just got to make sure they fit in the same bracket because they sit up, not sideways. should fit.
If you like i can take the stock bov to uni tomorrow. Melbourne Uni, in the city. If you'd like to try it out, or compare it to your stock one, you can come meet me sometime in the arvo.
my number is 0413 934 330
