The GTT wheels rub on the front R32 typeM calipers.
The way I see it I've got four options.
1. Fit a 3mm spacer to the front. (Probably not legal)
2. Shave 2mm off the edge of the calipers where they touch the wheel. ( $0 Quick and easy. They seem to have plenty of thickness but I don't like the idea of bodgying my calipers)
3. Have 2mm machined off the back of the wheels to clear the calipers. (Need to do 4 wheels so I can swap wheels front to back)
4. Fit R32GTR or R33 GTSt rotors and calipers.($$$)
What do you think is my best option?
https://www.sau.com.au/forums/topic/55589-r34gtt-wheels-wont-fit-r32/
Just got the spacer, 3mm is nothing to worry about.  Plus a spacer doesnt result in permanent change to anything.
Do you still have plently of thread for the nuts left? (ie my problem, there aint much meat there)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
