Guest white_r33
not sure if this is the rite place to post this please correct me if im wrong...
ive been tryin to search for some pics of some blue skylines i know they came out in blue but i think very limited is it possible to post some pics with this colour and if anyone knows the the name of the colour or colour code could they post it please thanks heaps :)
https://www.sau.com.au/forums/topic/5561-colour/
Guest white_r33
cool thanks :) im just lookin at my options im lookin at resprayin my car to either lime green or the porche yellow or the blue as above and im leanin towards the blue .. found the rims im after now its just a matter of settling on the colour i will be happy with white is shittin me
https://www.sau.com.au/forums/topic/5561-colour/#findComment-84347
white R33, hope I'm not sticking my nose in where it isn't needed, but I saw a photo of a white BMW that had a blue pearl clearcoat on it and it looked awesome - really subltle but still look twice material. Might be a bit easier than going the full colour change and give you a bit of a unique look, pretty sure you can custom just about any colour of pearl, or even a flip type eg, goes from blue on one angle to red on another - nothing too over the top, just a nice subtle finish - just a thought
Steve
https://www.sau.com.au/forums/topic/5561-colour/#findComment-86030
Dave,
That is a factory paintjob, they came out both two tone and full colour.. The factory paint code is BN6 which is 'Deep Marine Blue with Pearl". In fading light and under street lights at night it has a purple colour to it.
Brett
Edit. InitalD from perth has the two tone one with the green pearl. Don't think his is the same code as mine.
https://www.sau.com.au/forums/topic/5561-colour/#findComment-86499
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
