I have never seen it, BUT the S15 fronts are not a simple bolt on addition to the S13's so therefore, don't expect them to go on without modification onto cefiro or laurel.
However with the kits available for S13's i would not imagine it would be too difficult. Would look a bit screwed up in my opinion though.
https://www.sau.com.au/forums/topic/56130-ichigo-cefiro/#findComment-1089402
haha well its got some skyline bits, and its got some s13 bits... and maybe more :) *oooh the suspense*
i wouldn't say bolted... lol you should check out some of the conversion jobs, shit like held on by an aluminium bracket that you can bend by hand n stuff. Then there's the bog jobs... thems real fun.
https://www.sau.com.au/forums/topic/56130-ichigo-cefiro/#findComment-1089427
Actually the kits for the S13 and RPS13 isnt that difficult.
Ive seen the kit for it and its easy to put together... i was going to get one for my mates RPS13 for 1800 including the lights, flared guards and vertex bar.
https://www.sau.com.au/forums/topic/56130-ichigo-cefiro/#findComment-1089546
isn't she purrrdy? we found her in the scrap parts section of yahoo auctions, checked the VIN, it was a 1989, only problem was that the engine was siezed, so we organised it to be trucked to the port and loaded. couldn't make up some ramps coz it was too low n stuff so had to send the mechanic out to mess with it.
Interior is clean as, with custom gauge install (not usual caveman style drill holes everywhere and poke shit in) in the centre console etc.
cost next to nothing cos it was a part taking car :)
https://www.sau.com.au/forums/topic/56130-ichigo-cefiro/#findComment-1089950
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
