hi every one,
I had an incident involving a curb last saturday night, when I had my ambitions mix up with my capabillitys, and decided to go drifting my gtr. :Oops:
anyway, I slid the ass end into the curb and took out my rim, lower controle, and hicas steering rod, and was wondering if anyone had an old hicas rack so i could buy a rod off it and im also chasing a rim its a advan racing three spoke 18"x10" to suit 275, 35, 18 tyres, I realise this rim is rare, so even a second hand set of 18x 10 inch rims I would cosider buying rather than buying a tyre/rim set and wasting 2k worth of tyres :P
if ya wondering what the rim looks like have a look at these pics
https://www.sau.com.au/forums/topic/56291-whoops-hit-a-gutter/
I found another rim place in Kenwick when I was driving home one day from work, never heard anyone mention it before though.
Spoke Wheel Services
Unit 6, 34 Davison St Maddington 6109 (08) 9459 2035
Mates sister mashed her 33 with those same rims on them about 6 months or more ago so I know there's 3/4 or 1/2 a set of those rims floating around perth. Somewhere.
Shaun
Might be a good chance to buy a hicas lock kit. These don't normally come with the tie rods, but you can get these fairly easily. Mine were worn and Wilkinson's Suspension had some second hand.
There are also quite a few options for rose jointed lower control arms as well. I got mine (altough not fitted yet) from a guy over east who makes his own up. Try posting in the wanted to buy or suspension sections.
Mark - you've got an R32, right?
If so, this is easy, this just involves dropping out the whole rear rack including valves etc and replacing it with a fixed bar. The tie rods screw into this. The hydraulic hoses are disconnected and the kit comes with bolts that block off the hydraulic hoses.
I think that just aout every workshop sells these now. I know that SST, C-Red and Hyperdrive all can help you out with these. Again, there is a guy on the forums here who sells them for a $100 (off memory?).
Ok - the R33 is a bit more complicated as it has the Super HICAS - i.e. the electro version (and not the R32 hydraulic).
Tomei do an electronic module that fools the HICAS computer into thinking all is OK. This kit only comes with washers/shims that lock the existing bar, however.
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
