  • 3 weeks later...
Great Cruise Guys, :rave:
Reminds me of the good old Dawn Run, it was great to see so many people enjoying the Mountain, I was surprised we didnt get a visit from the local constanbulary.
Thanks for allowing a Rotary in the mix, the SKYLINE was out of Rego!
Heres are few pics
Hahaha I Think I Was Following You Back Through Bells Line Rd ...hahahaha I Was In The R34
Good Day Had By All .
Yeah,
It was a great run home, I had my mate driving who couldnt believe the corner speed you can carry in an RX8, he kept backing off and all he could here from me was "Keep you foot into it and you will be surprised", it took him a while to get used to the cars phenominal handling capabilities.
The R34 looks tough, and sat thru the twisties pretty flat, see you next time
Hey,
Good to see a couple of you SAU guys joining the SNSW Bathurst cruise. I hope you all enjoyed the day, it was nice to meet those of you who attended.
It was nice to see a good turn out of cars, i think we counted near the 50 mark when we hit the mountain.
Anyhow, we should be organising another major cruise in the next 4 months or so, keep your eyes open and i hope to see you guys on our future cruises.
Regards,
Dean
