guy who I bought my engine off had another RB25 running twin turbos in a VL.. went pretty well he said...
can be done... people are a bit dismissive of it, but if done correctly I think it can be a good combination.
Having done the conversion, I would IMHO save your money and build a monster single. But on the other hand I went twin turbo to be different. So each to their own
We used GTR manifolds. They won’t fit at all. You will need to cut the flanges off, and re-weld on to suit the rb25. (Not a big deal).
Turbo’s were rebuilt HKS 25/30’s. Started to pull really hard around 3800rpm, and went all the way to red line – 8500rpmish from memory.
As the motor was in a Silvia, the pipe work was a bitch, and heat was a major issue having the two low mounted. Not knowing what car you wish to do this conversion in, I can’t really comment.
Cost for cost building an rb25/rb30 hybrid with a single would be cheaper. I wont say the price of my motor but think in the field of $25k++ with its support gear.
Power was around the 600rwhp on c16. Ran 10.8 @ 127mph with the brakes on hard half-track to stop braking out, but still did. At a guess it should have been an under 10.5 car. Will never know as the car is now sold.
All the mod’s as follow;
1994 Rb25. Taken out to 2.6lt.
Forged pistons to suit.
Compression changed to suit pistons.
Fully balanced.
O ringed block.
Major head work/polished.
275 HKS cams.
Custom cam gears.
N1 Oil pump.
Q45 throttle body.
Custom aluminum radiator.
Custom FMIC.
Greddy BOV.
Power FC with hand controller.
Apexi boost controller.
HKS 2530 turbo’s.
HKS dump pipes.
GTR front pipes.
GTR twin turbo manifold, and pipe work.
HKS 4inch super dragger exhaust.
1000cc Sard injectors.
300zx AFM.
Apexi pod filter.
3/8 fuel lines.
Big competition fuel filter.
Malpassi fuel regulator.
Berry clutch. 3800pounds
Greddy inlet manifold.
Twin 12inch thermos.
GTR master cylinder. (Brake and clutch)
Im sure there is more, But its been a damn long time since I've had to think what the car had.
Josh.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
