Hey guys
my clutch on my r32 gts-t is on it's way out. Tonight started to slip in first at the top end.
So what I probably want to look at is getting a new clutch but I want something a bit more bitey than stock and not as bitey as a brass button.
So really i just want something better than the stock clutch. I dont want a clutch that would make my car imposible to drive.
So if you's guys have any thoughts what would suit me best it would be greatly apreciated.
Thanx Guys.
https://www.sau.com.au/forums/topic/56740-new-clutch-qs/
My mate got an organic centre which is pretty nice but not ridiculous - I stalled it first time I got in it but 2minutes later I was used to it and it drives great... When I get my next clutch I'll be getting the same.
He has a stock r32 and (over)paid $800 installed.
https://www.sau.com.au/forums/topic/56740-new-clutch-qs/#findComment-1098207
My mechanic has quoted me $800 for an organic twin plate clutch fitted with the flywheel machined. I have been trying to decide on a heavy duty or twin plate and i think the twin will be better in the long run. He quoted $550 for a heavy duty fitted.
If you want his details send me a pm
Steve
https://www.sau.com.au/forums/topic/56740-new-clutch-qs/#findComment-1098680
Hmm that's realy tempting there R33 steve.
I called the mechanic i usually go 2, I'm going 2 get him 2 have a look @ it 2morrow,
For a quote.
Is the twin plate going 2 be hard to drive with or still has enough give to drive round through traffic easily.
https://www.sau.com.au/forums/topic/56740-new-clutch-qs/#findComment-1099145
how much power is it making?
I emailed Exedy asking what they could offer me for an rb20det, had to hold at least 200rwkw etc. They suggested their sports organic kit, part number NSK-7056SO.
The max torque rating on this clutch at
7000 rpm is 393 ft/lb at the flywheel, max 524 hp or 391 kw also at the
flywheel.
Unless your trying to hold a whole lot of power, this kit might be worth a look.
goodluck
Tim
https://www.sau.com.au/forums/topic/56740-new-clutch-qs/#findComment-1099708
Ok.
Thanx Steve for the advice. I probably stick to the heavy duty clutch. Might get a daiken heavy duty clutch I think.
I might change it after the new year. As it seemed to drive alot better today.
Would not slip on me. I even droped the clutch and it slipped just a little. So in the new year new clutch.
Also gives me abit of time to get what i realy want. Which at the moment is becoming more clear.
Thanx guys for the input its been of great help.
https://www.sau.com.au/forums/topic/56740-new-clutch-qs/#findComment-1100950
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
