yesterday i tried to put a cash deposit into someone else's account however it wasnt the same bank account as the branch i was at so they wanted to charge me 3.50 then they did not allow me to put a deposit because i didnt provide them with branch details???? anyone ever experienced something this hilarious b4?
:Oops:
https://www.sau.com.au/forums/topic/56749-banking/
farking banks ... they ****ing charge for everything these days and they dont' even have toilets ....
gets this, if u have a cheque written out to you and there is a wording mistake ie words say its six and the number states 60 cents, the bank will take the difference ie 54 cents and take it as a fee!!!
i'm not shitting you either ... its happened to me 3 times already.
https://www.sau.com.au/forums/topic/56749-banking/#findComment-1098408
yeah if it was other bank thats how it always has been
if u want to take money from your account, say a NAB account, and give it to someone with a CBA account, they best way is to take out cash, walk to the nearest CBA branch, and deposit it there. or even better do it through internet banking.
i didnt realise you meant complete other bank i thought u meant just a different branch of the same(surprising if it was the case)
https://www.sau.com.au/forums/topic/56749-banking/#findComment-1099296
well then u would probably have to go to the building society :)
it would probably actually be processed by either commonwealth or westpac so you might be able to go to one of their branches. best to just look up which bank it is by asking a branch to look up the bsb they should know.
the only actual banks in aus are
anz, wbc, cba, stg, bwa, rba.
all the building societies and stuff like that are actually processed by one of the large banks.
https://www.sau.com.au/forums/topic/56749-banking/#findComment-1100703
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
