Hi people,
I have installed a 4ch amp into my car and it is an Old School one that a friend just gave to me and seems to work rather well and am very happy with it. However, I want to add a sub as the ol 4" splits and 6" in the back dont offer me enough kick. I have a 15" JL Audio Sub that i had in my last car and i want to use it as i couldnt stuffed buyin another one.
MY plan is to run 2ch bridged into sub and other 2 running my splits. 6"s will run off my head-deck.
Question : Because the Amp is OLD it does not have a high low pass switch on it, and i am wondering if anybody has heard of a High Pass Filter that is available that i could use for my sub (much the same way as the cross overs work for my splits) ??
Does anybody have any ideas?
Appreciate any feedback !
Cheers
HAro
https://www.sau.com.au/forums/topic/56880-high-low-pass-filter-question/
First, you need a low-pass filter for the sub (the one that lets the low frequency through). I am pretty sure if you go to any car audio place they ll be able to get you a stand alone filter. I would also recommend high-passing the speakers as well. This will allow the speakers to be much louder in treble and midrange.
Alternatively you can construct your own filters from a coil and a capacitor. You will need to research how to do this to get good sound quality. I made a set of high-pass filters for my 4" speakers and the result was awful, the bass filtered out but the distortion was pretty bad. This however will probably work on a low pass filter since the distortion is mainly in trble.
Go to your audio store and i am pretty sure they ll help you.
Low pass hey?
Sounds like a plan, i will roll out to a Jay car over the next few days, these forums are tops for gettin some answers quickly.
Thanks Guys, now all i have to do is organise a time to pull apart all my "install" and get into it!
Cheers
Haro
OK... Done like a dinner !
The low pass filter from Jay Car was about $30 so thats ok. Didnt have to build it or anything, just bought it off the shelf. Works a treat. Now i just have to work on that bloody engine whine noise that soo many people get. I think i just will try a better amp.
Thanks for your help people.
HAro
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
