Howdy All,
Just a bit of info for all fellow Stagea type people. And that is that the fuel pumps on the RS4's aren't the same setup as the ones on the R33's.
I went to change mine today, undid the big black plastic locating ring, pulled the cap up and there was only the fuel gauge sender hanging off of it !!! The pump is mounted to the right/bottom side of the fuel tank. Not like the R33's were the pump is mounted to the big cap thingy :)
Soooo, I could be wrong here, but I would say that we'd have to go external if we want to upgrade the fuel pumps, as getting to the factory one down the bottom of the fuel tank is gunna be close to impossible :(
J
P.S. - Anybody want to buy a Walbro internal for $150 + postage :kick:
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/
Interesting.... And the reason I say that is in the Nismo catalogue the 260RS pump is listed as the same as the BNR32 (not BNCR33). Is the tank different, or????
I was considering the R32 pump in my car as a first choice, but it seems that matters may be slightly complicated.
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/#findComment-1103389
You have to be able to get to the pump to service it. There must be a way. As for the Stagea tank being the same as the R32 tank, my Stagea tank is molded plastic and the R32 tank is fabricated steel.:cheers:
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/#findComment-1103854
Ahh, very good.
Was it difficult getting the factory mount/bracket out ? When I had the big cap off, it looked pretty damn hard to get to the mount/pump to get it out.
I was going to take a photo of it but I was a bit worried about using the flash around the petrol.. lol
J
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/#findComment-1106193
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
