PICS ARE UP!!
http://www.carsales.com.au/pls/carsales/!q...ype=0&ad_type=1
I have a brand new 400R bodykit for R33 GTST, includes
front bar, side skirts and rear bar $700
Two different styles of 400R front bars, difference is in the side air vents and the bottom of centre
3 have been SOLD and 1 is left = $250
I have a Explosive half rear bar which connects straight on top of the stock bar. Brand New, raw, ready to be primed and painted. $200 with the m spec rear bar (Looks very similar to 400R rear bar)
http://www.jetspeed.com.au/showModel.php?id=1297
If sold this week will drop price !!
Pick up in sydney preferred but will send interstate at buyers expense
Mob: 0414 096 594
https://www.sau.com.au/forums/topic/57649-r33-bodykit/
is the kit all brand new?
or has it been used before?
what sorta quality is the fibreglass?
and about the 400R front bar.... does it come with the mesh + indicators, or just plain and does it require prepariton or is it ready to be primer coated.
Answer all questions plz, im sure other ppl would be glad to know this info as well.
ahh yeh, how many of them have you got? or are u trading with them.
thanx
cheers.
https://www.sau.com.au/forums/topic/57649-r33-bodykit/#findComment-1111069
Compared to many other kits i've seen on the the market, this one is much thicker and better quality, it's brand new never used, ready to be primed and painted
https://www.sau.com.au/forums/topic/57649-r33-bodykit/#findComment-1111189
Three 400R front bars have been sold, Two pairs of 400R skirts have been sold, Rear bar has been sold, One 400R front bar is left = $250 and Explosive half bar with m spec rear bar = $200
https://www.sau.com.au/forums/topic/57649-r33-bodykit/#findComment-1113389
Its not missing mate, this is the new design, the old design of the dark grey shown in the photo only has that part in the middle, also the side air vents are different
hey mate with the pic of the blue front bar, the bar across the front is missing, making the gap bigger, why is that?
do u have one with it still on there?
https://www.sau.com.au/forums/topic/57649-r33-bodykit/#findComment-1113452
yeh, it looks good but there will be a gap under the were the front mount sits, as in most cases i have seen fron mount finish along that middle part.
will u be able to get those pics by tonight? side and front angles would be nice?
cheers mate
https://www.sau.com.au/forums/topic/57649-r33-bodykit/#findComment-1113672
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
