Check this out. A roads engineer in europe has started developing roads with no traffic sighns and has expeirenced a large drop in the number of accidents on said roads.
Man Aussie traffic engineers would have a heart attack.
http://www.wired.com/wired/archive/12.12/t...tw=wn_tophead_7
Just goes to show that road safety is a state of mind. Without road signs at a busy intersection we use our own brains, rather than following directions, there is no one to blame for a duck up.
Sort of goes along with my road safety idea - put razor sharp 400mm long spikes on everyones steering wheel pointing at your neck as you drove. You would not speed or do anything stupid then would you.
Gotta love Holland though, always willing to try new things, unlike the conservative left bullshit we have over here.
"Gotta love Holland though, always willing to try new things, unlike the conservative left bullshit we have over here."
Consrvative left is a contradiction in terms........
oh and it dosent work at that big roundabout in france, i cant spell the name...........no road markings etc and it just makes people more agressive cause it dosent put them in the blame.............
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
