My Stagea is a 12/96 RB25DET Auto with a DAVZ body kit, 77,000 klm and of course regularly serviced.
Blitz Front mount, Blitz Exhaust, Blitz Dual SBC, Blitz Turbo timer, Apexi Pod Filter, Usual guages.
Tein Coilovers, New East Bear R34 GTR Seats with Bride rails, Cuzco brake cylinder stopper.
And the usual BOV, air oil seperator and TV. Apexi SAFC just tuned at SST and made 231 at the rear wheeels.
$24,000 ono with East Bear seats and everything else, wont do the usual take the good stuff out before selling.
If you want more info email [email protected]
Selling due to another car has arrived.
Thanks,
Photos at http://www.skylinesaustralia.com/photopost...2&ppuser=5805&=
__________________
https://www.sau.com.au/forums/topic/59040-stagea-with-a-few-extra-bits-25000/
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
