We are still finalizing a navigator for TT2005.
If anyone out there is interested, then maybe a PM to me would not be a waste of time...
If you are a current or past motorsport competitor, know what it takes to fit in a winning team and are capable of bringing some budget to the team please continue and PM.
If you're idea of fun is long days of extreme concentration, capped off by overcoming the challenge of one of the toughest events on the Oz calender, then tell me why I should call you.
Primmadonnas dont waste youre time...
TT
https://www.sau.com.au/forums/topic/59166-targa-tasmania-navigators/
TT
hi mate my dad is a targa navigator and so is our next door nieghbour
our next door nieghbour could be interested shye has done it about 4 times i think
if you want i could go and ask her if u want ?
i dont think my dad is interested as after 7 times he needs somthing else
cya mate
  • 1 month later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
