Hey guys.
I have a problem with my speedo. the kms traveled stoped cliking both the top and the bottom but the speed is still showing and so does everything els, could it be the actual hole speedo shit it self?
Some times it would work for like 15 seconds and thats it. i checked all wires behind it and all is fine there.
im guessing its were its getting its signal from, witch i have no idea were thats from :Oops:
Please help :(
:D
https://www.sau.com.au/forums/topic/60585-r33-gts-t-speedo-problem/
probably because your odometer has been wound back at some point - usually a common sign. I wouldn't worry, most have anyhow.
What you'll probably have to do is take the cluster out, open it up, and replace or fix the odometer part which controls both the odometer and trip. Often it can just be a stripped gear.
Just gotta say that this is a very common problem, and I wouldn't be surprised if it wasn't related to "hanky panky" with the odo reading between Jap and Aus.
Mine played up on the way home from buying it at a yard in Sydney. When I fronted them they said that they would get it fixed no worries. I then said that, as I could not trust the odometer reading, they should do the 100K service stuff (timing belt etc) as well.
No worries. Got it done at 67K according to the odo.
Anyone who has bought from a yard and has this happen should do the same. I think you will find that they bend over backwards because of implications of "dodgyness".
If you have imported it yourself, I don't think there is anyone to go to and you gotta fix it yourself (through wreckers etc).
El Bee
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
