  • Replies 59
hahahahaa lozzle drunk at 940am this is confirmed :P
hahahha
silwa v SAU volley ball comp.. anyone up.. :confused:
and what sport we playing? anyone layin down the law and saying which one we gonna do? :uh-huh:
hahahha
rules?
The governing body for the DOCS Olympic Volleyball shall be the U.S. Volleyball Association except as noted below:
  1. All opening rounds shall be round robin
    • Two games shall be played in pool play against each opponent
    • Teams not scheduled to play need to be available to work
[*]All games will be to 21 points, unless otherwise stated (rally scoring)
Playoffs will be best two (2) out of three (3) to win, unless otherwise stated
Triples games will be played to 15 (fifteen) points (rally scoring)
[*]To break a tie in a pool/bracket there will be one game to 21 points (rally scoring)
[*]The winner of the loser's bracket will receive third place.
[*]Mixed team play must have a minimum of two men and two women on the court at all times
[*]A team may have maximum of twelve players on its roster
FOLLOWING USA VOLLEYBALL RULES EXCEPT WHERE STATED
RULES OF PLAY
  1. THE SERVE: The server shall have 8 seconds after the referee sounds the readiness-to-serve whistle to hit the ball for service. The serve is to be made from anywhere behind the endline. The server may move freely within the service zone. At the moment of the service hit or takeoff for a jump service, the server must be completely in the service zone and not touching the court (end line included) or the playing surface outside the zone. After the service, the player may step or land outside the zone including the court. The server must contact the ball within 8 seconds after the first referee whistles for service.
  2. ROTATION: The team which receives the ball for service shall rotate one position clockwise before serving.
  3. SCREENING: The players of the serving team must not, through screening (moving or by position) prevent their opponents from watching the server or the trajectory of the ball. Screening is a fault.
  4. CONTACT WITH THE BALL: Each team is allowed 3 successive contacts with the ball except as noted in the Blocking Rule.
  5. CONTACT OF THE BALL WITH THE BODY: The ball may be hit with any part of the body.
  6. SUCCESSIVE CONTACTS: Players may have successive contacts of the ball during blocking and during a single attempt to make the first team hit of a ball coming from the opponents, even if the ball is blocked, provided the ball is not held
  7. HELD BALL: When the ball visibly comes to rest momentarily (in the hands or arms of a player). The ball must be hit in such a manner that it rebounds cleanly after contact. Scooping, lifting, pushing or carrying is a form of holding. A ball clearly hit with one or both hands from a position below the ball is considered a good play.
  8. SIMULTANEOUS CONTACT BY OPPONENTS: If two opponents simultaneously contact the ball and it remains in play, the team receiving the ball is entitled to another three hits. If such a ball goes "out," it is the fault of the team on the opposite side. A joust occurs when players of opposing teams cause the ball to come to rest above the net through simultaneous contact. A joust is not a fault, and play continues as if the contact were instantaneous (Rule 14.2.3).
  9. ATTACKING OVER OPPONENTS COURT: A player is not allowed to attack the ball on the opposite side of the net. When spiking, the follow through is allowed to cross the net without contacting the opponent.
  10. BLOCKING: Multiple contacts of the ball is legal during an attempt to block. Blocking a served ball is prohibited. Blocking is permitted after the ball is spiked, or intentionally directed toward the opponents side; or after the opponents allowable 3 hits; or after the opponents have hit the ball towards the net and no member of the attacking team is in a position to make a legal play on the ball; or if the ball is falling near the net and no member of the attacking team could reasonably make a play on the ball. Blocking a set ball before the spike is not allowable.
  11. PASSING AND RECEPTION OF THE BALL: Contact with the ball must be brief and instantaneous. Contact of the ball is permitted by the open hand, ball can not be lifted, held or thrown.
  12. PLAYER CONTACT WITH NET: Contact with the net either accidental or not is a fault. Hair is an exception. If the ball is hit into the net causing it to hit a player, such contact shall not be considered a fault.
  13. DEADBALL: The ball becomes a dead ball when: the ball touches outside an antenna, does not cross the net between antennas, strikes the floor or wall, contacts the ceiling or object attached to the ceiling which is 7 meters or more above the playing surface, a player commits a fault. A ball may be played off a lower ceiling or objects as long as it does not cross the net but is played on the same side. Net serve as long as ball passed between the antennas.
http://www.2005worldmasters.com/bcm/wmgame...3D?OpenDocument
thats it.. ur goin down *note to self dont wear any loose clothing that might come off to possibly distract opposition...*
ahahaha loose clothing is fine haha :)
anywhos i thought of a new sport................. we can commit to a full schedule of DnB gigs at heat, we will be getting a full body workout and sweat it out hardcore by the end of the night :D
so what ya think? :headspin:
for the slows who don't get it............. I'M JOKING
adrian ;)
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
